Ritch Posted January 12, 2010 Share Posted January 12, 2010 Hi all, Just purchased a cheapo 300tdi which is developing faults quicker than I can fix em! I've been reading through the excellent timing belt change guide on this site but have a couple of quick q's about the crank pulley tool. The guide is here..... http://forums.lr4x4.com/index.php?showtopic=22319&view=&hl=timing belt 300&fromsearch=1 Les says... The crankshaft pulley is solid, as expected, so I have a DIY crank pulley puller - very simple device, but works every time.Unscrew the crank bolt a few turns, put the 27mm socket on it, then as the two m8 bolts are tightened a bit of a time each, the pulley gets drawn off the end of the crank. My first question is what is the gap between the "two M8 bolts" so I can do some Fab?? Second question is are they M8 threaded on all models as I couldn't get it to take an M8 in the crank pulley recesses today but I was a little rushed. Thanks in advance for any help. Ritchie. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 12, 2010 Share Posted January 12, 2010 74 mm between center lines and yes, they are all M8s. Quote Link to comment Share on other sites More sharing options...
Ritch Posted January 12, 2010 Author Share Posted January 12, 2010 74 mm between center lines and yes, they are all M8s. Much appreciated, Ritchie Quote Link to comment Share on other sites More sharing options...
