DenmarkThor Posted April 26, 2010 Share Posted April 26, 2010 I have a frequent problem with the ignition in my Discovery Td5 from 99. When I turn the key the lights are on but there is no reaction when I turn the key. There a no "relay-clicking" from the starter etc. It is just dead. After a few turns it starts at once and the problem can be gone for days and weeks. Quote Link to comment Share on other sites More sharing options...
ches Posted April 26, 2010 Share Posted April 26, 2010 had a the same problem recently and it was the starter solenoid contacts. a repair kit is available on ebay for approx £10. the starter has to be removed. the top bolt on the starter is the most difficult to remove,it is 15mm unlike the two easy bolts which are 13mm. you need a 3/8 drive socket on a 6" extension bar for easy removal. the 1/2 drive socket does not fit square to the bolt. Quote Link to comment Share on other sites More sharing options...
