coasty Posted March 21, 2011 Share Posted March 21, 2011 Hi all I am unsure what to do as I am due to fit my full external cage and tubilar front end. I will need to change the arches i have on the front and have been looking at the QT flexible rubber arches but there seems to be alot of people saying they tear off easily? Has any one else suffered this problem? any help would be greatfully received. Also if you have a set of the QT Arches would you be so kind to measure how thick the rubber is? (No where lists this in their measurements) Cheers Dave Quote Link to comment Share on other sites More sharing options...
stuck Posted March 21, 2011 Share Posted March 21, 2011 Dave, You don't say what you are using your truck for but if you are looking for a disposable solution get hold of a plastic 55 gallon drum and cut arches from that, they look surprisingly tidy but need a flange to fix to. HTH's, Mick. Quote Link to comment Share on other sites More sharing options...
