arborfieldx Posted June 13, 2011 Share Posted June 13, 2011 hi there folks...im new on here so i hope you all dont mind me being a bit dim...ok here is my problem..i have or had fitted on my discovery 1994 an after market immobilizer, cobra 0802T. it went wrong so i took it off by following the wires to where they joined the ignition loom, cut them and rejoined wires for ignition....now the car wont start. everything works, except the starter just clicks, battery did drain but recharged and the car will bump start very easily just a push along flat ground does it...i took it for a run for about half an hour stopped it, engine off, just a click again...any ideas out there...needs to get going by tomorrow as i need it for work.. also, is there a way i can bypass things for now just to get it going ive heard i can run a wire from starter to ignition switch, but from which terminal to which terminal.....mmmmmm thanks all Quote Link to comment Share on other sites More sharing options...
