Marten Posted March 29, 2012 Share Posted March 29, 2012 Ho Hum! Acquired a 1995 R380 gearbox "about 90K miles run", via a (trusted) third party, as part of the solution to my early 200 TDi Disco 1 LT box output spline/transfer box input gear erosion. After 2K miles I have a persistant low whine from the R380 box, more pronounced on over-run in the higher gears. Changed the (still bright and new looking) oil today and found more very fine debris clinging to the drain plug magnet than I would have liked. I certainly have a problem, but the box is otherwise fine and changes gear without a murmer. Fished around in the bottom of the box via the drain aperture and hooked out a 60deg arc section of a dark blue nylon ring. About 20mm inside diameter, 4mm wide, with inner edges slightly rebated and a shallow, raised outer collar. looks like a spacer or locating ring, but can't see an obvious match on the parts CD Rom. Has anyone stripped a box lately and perhaps able to recognise the part. Cheers! Quote Link to comment Share on other sites More sharing options...
Marten Posted March 30, 2012 Author Share Posted March 30, 2012 Update. Seems things may not be as desperate as I had feared. Discussion with a professional re-builder of R380 boxes reveals that there are no similar plastic/nylon parts in the box other than a bush associated with the selector mechanism. Whine is probably a failing bearing, so a gearbox strip is in the offing, but no panic! Quote Link to comment Share on other sites More sharing options...
