hammertm Posted June 20, 2012 Share Posted June 20, 2012 Hi, Just took the carbs/Manifold of the V8 and fitted the EFI Manifold - I am now short a pipe connection for the cooling system where the heater matrix joined the rear of the carb manifold. Can anyone give me any advice as to where i Should run this pipe to in the cooling system. My first thought was to put a T piece in the large diameter leg from the bottom of the radiator to the manifold. Cheers Dave Quote Link to comment Share on other sites More sharing options...
muttleyd Posted June 20, 2012 Share Posted June 20, 2012 One hose for the heater connects to the outlet on the back of the pump. The other to a connection on the front of the inlet manifold either lower right of the thermostat housing (looking front of engine) or upper right coming out at angle depending on the origin of the manifold. Currently working through this conversion myself. Seems relatively simple just time consuming mocking everything up and sorting out air cleaner brackets etc. Good luck with it. Quote Link to comment Share on other sites More sharing options...
hammertm Posted June 23, 2012 Author Share Posted June 23, 2012 cheers for the reply, but that would mean i have a spare outlet on the pump, or do I T it between the front of the manifold and the pump? Quote Link to comment Share on other sites More sharing options...
muttleyd Posted June 24, 2012 Share Posted June 24, 2012 Really. Think there are 2 bosses on the back of the pump, but only one is open normally. If not you could always blank one of them. Quote Link to comment Share on other sites More sharing options...
