manxrover Posted November 3, 2013 Share Posted November 3, 2013 Hi All If anyone is interested in a ABS Amigo V1-USB from RSW Solutions I have one for sale. Its a diagnostic tool for the Land Rover Discovery 2 and TD5 only. You can seen how it works on the RSW web site on You tube. It resolved my problems, as after many hours of searching for the ABS fault, and replacing most of the ABS system and brakes, purchased this from RSW in the USA and found the problem first time, it appears that some ABS leads that are not OEM are a tad longer 05mm and rub on the ABS pickup causing the fault, a small fibre washer resolved the problem 6 months on no lights. This ABS Amigo does not reset the fault codes only finds them. Also have a Land Rover Becker sat nav with discs and antenna removed from a 2003 TD5 but will fit any Discovery TD5 with a small addition of a speed wire connected from under the steering wheel and spliced into the sat nav harness, easy job. See TD5 web site for details. interested offers to phenix@manx.net Brian Quote Link to comment Share on other sites More sharing options...
