Marten Posted July 5, 2016 Share Posted July 5, 2016 My 1992 Disco 1 has 1995 replacement front doors with electric drive. Have just replaced the regulator track on the bottom of the RHS glass but made the mistake of slackening off what appears to be a cam adjuster and the regulator arm relationship has changed allowing the window glass to tilt out of alignment. The adjuster parts ended up in the bottom of the door. Assuming I can replace the parts in-situ in the correct order, can the adjuster be set up without having to remove the regulator from the door? Access and visibility are very poor! 2 Quote Link to comment Share on other sites More sharing options...
