mgwanderer Posted September 17, 2015 Share Posted September 17, 2015 Ok as a new member I have problems and hope to find some good advice here. Charging light comes on occasionally when driving but it seems to be ok when I check the voltage it seems to be giving an output as the voltage is at the battery is 13-14v The more important one is that I get "gearbox error traction is reduced" but the car drives well and appears to pull well but when I go to special programmes it tells me gearbox error. This is an autobox but gears change up and down on normal driving without problems. When I try to read the faults with my obd reader it says no faults... What can be wrong Many thanks in advance Clive Quote Link to comment Share on other sites More sharing options...
Tanuki Posted September 18, 2015 Share Posted September 18, 2015 First thing - check and clean all the earths. The main one from the battery -ve terminal to the chassis, and the one from the chassis to the engine-block. If you get even a slightly-bad contact in the earth circuit back to the battery it can cause random voltage-drops which will throw all sorts of odd and inconsistent/unbelievable fault codes. Disconnecting and cleaning the battery terminals would be a good place to start [check you have your immobiliser/alarm and radio security codes before you do this as you'll need to know the relevant procedure: LR security sees disconnecting the battery as a hostile attack!] Second - what mileage has the vehicle done? At high(ish) mileages - 70,000 miles or more, the brushes in the alternator can get worn to the point where they don't make reliable contact with the slip-rings. When this happens the alternator can intermittently stop charging properly - giving you the warning-light, and the sudden voltage-drop when you have to fall back to battery-only power can again cause various other issues of electronic confusion. Quote Link to comment Share on other sites More sharing options...
