Landy 90 Hybrid Posted March 14, 2008 Share Posted March 14, 2008 I have a topic in the Defender section, but thought I would put one in here too as most of my Hybrid is RRC. She has a 3.5 EFi, on petrol in, and I have been having some running probs of late. Running lumpy, spluttering when driving, especially when putting foot down. Fine on idle and reving up at stand still. Have done a few checks from the diagnostic manual, downloaded from here, and the results are as follows: Lucas 2AM AFM Test 6 - Voltage across resistor wire in AFM potentiometer - should be 1.55v - actual 1.55v Test 7 - Voltage through AFM potentiometer & the wiring to ECU Step 1 - should be 4.3v +- 0.2v - actual 4.34v Step 2 - should be 3.7v +- 0.1v - actual 3.72v step 3 - should decrease to 1.6v -+ 0.1v - actual 1.66v Test 8 - Ohms - Check internal resistance of AFM and wiring to ECU .............actual readings at.....ECU ...AFM Plug.... AFM socket Pins 6 & 8 - should be 360K - 396K....395K..........395K Pins 6 & 9 - should be 560K - 616K....614K..........614K Pins 8 & 9 - should be 200K - 220K....219K..........219K Test 9 - Voltage at throttle pot Step 1 - should be 4.3v - actual - 4.3v Step 2 - should be 0.325 - actual 0.30v (within tolerance) Step 3 - should be 4.5v MAX - actual 3.78v Test 10 - Resistance of air temp sensor in AFM I didnt have a temp probe so couldnt measure the temp, but measured the resistance and was within the scales provided Given that the voltages are mostly within tolerance, but the internal resistance of the AFM was quite a way out, how would this effect running, does it look like this could be causing me problems? Thanks in advance for your help Jonathan Quote Link to comment Share on other sites More sharing options...
