chrisstevenson Posted September 26, 2006 Share Posted September 26, 2006 Hi, Just picked up a P38 auto, diesel, very nice, but like an idiot when test driving it I selected the low ratio box and then went to put it in reverse whilst the warning beep was being emitted, as soon as I heard the resulting crunch I put it back in neutral. Now my qustion is this... am I likely to have done any serious damage to the box? Having now read the owners manual it does warn that you could 'crunch the gears' on a manual if you force it into gear before the car is ready for low ratio mode, so I guess a little crunching of gears is expected on the rare occasion? Hate to think I've just knocked 50,000 miles off the box already! Quote Link to comment Share on other sites More sharing options...
fisha Posted September 27, 2006 Share Posted September 27, 2006 youre not likely to have done any real damage. in terms of shifting between high and low, just throw the lever across and wait till the beeps stop. on the last beep you can hear the gears engage with a clunk/click sound. then you can select a forward or reverse gear. mine throws a wobbler if you are moving or try to select a gear too quickly by beeping and showing messages on the display. Woudn't worry about it unless its crunching time after time . . . which by the sounds of it, it isnt' Quote Link to comment Share on other sites More sharing options...
chrisstevenson Posted September 27, 2006 Author Share Posted September 27, 2006 Thanks! How does the system work, is the meshing of the transfer box servo operated? Quote Link to comment Share on other sites More sharing options...
fisha Posted September 28, 2006 Share Posted September 28, 2006 basically yeah, its a servo motor thingie. so it pays to change between HIGH and LOW on a periodic basis to make sure it stays working. ( actually, the Disco 3 does a full swing with the transfer box when you switch it off specifically to address the issue of the motor seizing from lack of use . . . . anyway i digress ) this should be enough info: Quote Link to comment Share on other sites More sharing options...
AndyC Posted September 28, 2006 Share Posted September 28, 2006 actually, the Disco 3 does a full swing with the transfer box when you switch it off specifically to address the issue of the motor seizing from lack of use . . . . anyway i digress How long before someone parks one up and finds it in Low when they get back? Andy Quote Link to comment Share on other sites More sharing options...
fisha Posted September 29, 2006 Share Posted September 29, 2006 funnily enough my thought was how long till it wears out when the development guy from LR mentioned it. Quote Link to comment Share on other sites More sharing options...
AndyC Posted October 4, 2006 Share Posted October 4, 2006 Which only goes to prove my friend's saying "it doesn't matter how cynical you become, it's never enough to keep up". Quote Link to comment Share on other sites More sharing options...
