tpress Posted April 3, 2016 Share Posted April 3, 2016 Hoping to get advise on the following.. I have fitted a turbo vacuum guage and I fitted into to the T piece in the pipe near the brake servo that was blanked off from when an EGR delete as done by the pervious owner. It seems to work and I am not overly interested in absolutely accurate readings but wanted to confirm that this is an ok place to install it or if there is a much better place. Thanks Tim Quote Link to comment Share on other sites More sharing options...
tpress Posted April 4, 2016 Author Share Posted April 4, 2016 Ignore the post, I was being daft and I know I need to put just off the manifold and turbo !! Quote Link to comment Share on other sites More sharing options...
Boydie Posted April 5, 2016 Share Posted April 5, 2016 You also need to use pressure hose, the clear plastic hose in the photo will quickly expand with pressure and heat and be useless. The fitting on the rear of the manifold is the same thread/type as the breather fittings on the axles and gear boxes so you should be easily be able to acquire a banjo bolt and connection from your dealer or local spares/wrecker. Quote Link to comment Share on other sites More sharing options...
