adeb Posted December 9, 2006 Share Posted December 9, 2006 [font="Comic Sans MS"]I have after a long time finally got my landrover running. Sorted timing, had new fuel injectors, and it now starts first time. The only problem now is after about 10 minutes of the engine running, engine will stall, and theres a build up of air in the top of the filter. Have fitted a non return valve between the lift pump and the filter, renewed all pipes and fittings, with new hoses, unions, and clips, new lift pump, reconditioned distributor pump, new copper washers I have replaced pipework back to fuel outlet in tank, I therefore assume than that this is the likely cause of the problem. Has anyone else had a similiar problem, and if so any suggestions.[/font] Quote Link to comment Share on other sites More sharing options...
