Tetley Posted February 29, 2020 Share Posted February 29, 2020 Aye Up All, 1997 D1 V8. I have a slight amount of vertical play at the steering wheel when it is in the upper setting (It’s fine in the lower setting). I suspect that it is something to do with the height adjuster but can't find a means of sorting it. I’ve had the column cowl off and found a loose bolt head either side of the column which I’ve tweaked a bit but it hasn’t made any difference. (Not sure how tight they should be? There is no sign of any bump stop on top of the mechanism - should there be one? Anyone else had/sorted this issue? Thanks Quote Link to comment Share on other sites More sharing options...
