the_blasons Posted September 16, 2007 Share Posted September 16, 2007 Hi All, Need some help with a fuel problem. I've got a 92 200tdi disco. i've let the disco stand for a few weeks but used it everyday prior to that. came to start it yesterday and it wouldn't start! Turned over fine but wouldn't fire. Checked a few things but couldn't fine problem. so worked backwards with fuel, cracked injectors in case it was a air lock in fuel, turned it over but not fuel to injectors. went to fuel filter and did the same but fuel was being delivered there ok. check inlet to fuel injection pump, fine there as well. But when i tried outlet of the pump no fuel coming through??? Can someone tell me what i should do to fix this problem!!! Regards The Blasons Quote Link to comment Share on other sites More sharing options...
coco Posted September 16, 2007 Share Posted September 16, 2007 Hi check fuel stop solinoid has 12v to it with ignition on, or has no stuck closed. Quote Link to comment Share on other sites More sharing options...
