gus Posted December 30, 2007 Share Posted December 30, 2007 I have the TD5 here now! I also have a brand new NNN ECU here. I'm just waiting for my Nanocom (Paddockspares is closed until januari )I just plugged in my new ECU to see what happened, I didn't expect the car to start without programming the ECU. When I turn on the ignition I only here a lot of clicking noises from the ECU (or the relais near the ecu) and the check engine and hazard lights warning lights keep flashing. Is this normal behaviour when plugging in a non programmed ECU? You can read injector codes under the engine coer: Each injector has a different code. With nanocom go to "ecu setting" and type injector codes. After chose the tip with 2 ways accelerator. Send configuration to ecu, go with nancom to "learn alarm code", press and wait for 15 secons. Turn on your new Def td5 an enjoy it. Good luck!. Quote Link to comment Share on other sites More sharing options...
stobbie Posted December 30, 2007 Author Share Posted December 30, 2007 Thanks, I'll try that. Hope my nanocom arrives soon! Quote Link to comment Share on other sites More sharing options...
