jimmy mad Posted January 6, 2008 Share Posted January 6, 2008 hi was just wandering how much rotational play is normal in the transfer case diff between the two output flanges when dif lock is ingaged is dont have much expericance with ld transfer diffs?? i have about a 1/3 of a rotation before it starts to rotate the other side you can rotate the front output flang about a thrid of a turn back and fourth before the rear output shaft moves the gear box input shaft is not moving until i rotate it anothe so both flanges turn is this normal or nackered and how hard is it to repair chears Quote Link to comment Share on other sites More sharing options...
