Bulkhead Removal & Seatbelt top mounting
davidfox123
Anybody thought about making a bulkhead removal bar that then continues up and across the roof with strengthening supports leading back to the top of the tub. Idea being that when you move the seat backwards the belts are moved back as well so that they don't cut across at the wrong angle. If not does anybody fancy a go as I can't weld!!!!!
