Jaywood Posted May 2, 2008 Share Posted May 2, 2008 Rear step on our Defender90 is rattley on the two bolts which hold it. The nuts are captive in the cross member and the bolts may break if we foece them trying to tighten them up. Any ideas if we remove it by sawing the bolts for instance as there doesn't seem to be access to refit it. All contributions accepted with thanks - (dealer thought £30+ to 'rivet' it !) Cheers. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted May 2, 2008 Share Posted May 2, 2008 Hi Do they just hold the step on or are they part of the towpack? if just the step then undo them, drill the nut out and put a new nut on the back, Mike Quote Link to comment Share on other sites More sharing options...
