Defender 90 rear step
Rear step on our Defender90 is rattley on the two bolts which hold it. The nuts are captive in the cross member and the bolts may break if we foece them trying to tighten them up.
Any ideas if we remove it by sawing the bolts for instance as there doesn't seem to be access to refit it.
All contributions accepted with thanks - (dealer thought £30+ to 'rivet' it !)
Cheers.
