rhydgte Posted May 13, 2008 Share Posted May 13, 2008 Hi guys sorry for yet another thread relating to dash lights - this time the lack of one! Engaged diff lock in low and high range and no light comes on the dash, bulb is fine (have changed it for a new one) Is there wiring anywhere that might be loose or have come unconnected? Any easy ways of checking diff lock is working properly with it on the drive? Cheers for your help once again Quote Link to comment Share on other sites More sharing options...
russ3120 Posted May 13, 2008 Share Posted May 13, 2008 if memory serves, there is a switch on top of the transfer box, you need to remove the centre console to get to it though where abouts in mid wales? Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 13, 2008 Author Share Posted May 13, 2008 if memory serves, there is a switch on top of the transfer box, you need to remove the centre console to get to it thoughwhere abouts in mid wales? Newtown in Powys mate, I was in Brecon last week on a training course! Cheers, will have a look! Quote Link to comment Share on other sites More sharing options...
Skanny Posted May 14, 2008 Share Posted May 14, 2008 Jack ONE wheel up and try and turn it with diff lock NOT engaged, it should turn. Then engage diff lock and it should NOT turn. There is a switch on the box that turns the light on, check the wiring on it. Also make sure no one has forced the lever and bent the linkage thus not allowing it to select difflock or not. You NEED that light to work so you dont go off flat out on the motorway in diff lock = BANG! Quote Link to comment Share on other sites More sharing options...
