woff Posted May 29, 2008 Share Posted May 29, 2008 I thought that I may share my experience with all. I removed the under engine tray earlier this year to repair a leaking water pipe. The only way I could remove the tray as it was already cracked was to break up the tray in situ. However I'm now slightly regreting that now. From the wet weather weve just had created a slight issue that I came to a "T" junction and went straight on. Not turning right where I wanted to go but into the hedge the other side. I put this down to the fact that the water that I was in was making my fan belt slip so I had significant reduced steering. I'm going to retrofit a shield to stop this as you would be surprised as to how much steering you don't have with out PAS. Quote Link to comment Share on other sites More sharing options...
