pindie Posted June 16, 2008 Share Posted June 16, 2008 Hi, My pipes leak at the top of my in tank pump. The black is the worst but the green also seeps. How can i stop these leaks? 03 Td5 Disco auto Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2008 Share Posted June 16, 2008 Have you recently disconnected the pipes? They make a very positive click when they are connected properly. If they have started to leak for no apparent reason, then you could try seperating them, cleaning the connection, apply a small amount of grease on the male end, and see if that cures it. Otherwise, the connections will have to be replaced. Les. Quote Link to comment Share on other sites More sharing options...
