Wilf Posted June 18, 2008 Share Posted June 18, 2008 hi guys I have a 2000 Td5 Disco which never gets washed or cleaned etc. (it's a landy!!!) Whilst we were skiing back in February (in France) one of the rear air springs went so it had to go into the local dealer in Chambery. The blighters replaced the air spring but had the cheek to wash the car, presumably with a power wash. Half way back up through France i spotted that the front electric sunroof was now not working. I also now get the leak through the driver side sun visor/map pockets. I presume that the leak is most likely to be the drain blockage thing - has anyone found an easier way to get to them rather than taking off the head lining - or can you rod or blow them clean by getting to the lower end at the rear light cluster? but most importantly - i want to fix the sunroof - any ideas (I've checked the fuses etc.). I've not heard of any common problems with the electrics for the s/rs cheers wilf Quote Link to comment Share on other sites More sharing options...
Skanny Posted June 18, 2008 Share Posted June 18, 2008 hi guysI have a 2000 Td5 Disco which never gets washed or cleaned etc. (it's a landy!!!) Whilst we were skiing back in February (in France) one of the rear air springs went so it had to go into the local dealer in Chambery. The blighters replaced the air spring but had the cheek to wash the car, presumably with a power wash. Half way back up through France i spotted that the front electric sunroof was now not working. I also now get the leak through the driver side sun visor/map pockets. I presume that the leak is most likely to be the drain blockage thing - has anyone found an easier way to get to them rather than taking off the head lining - or can you rod or blow them clean by getting to the lower end at the rear light cluster? but most importantly - i want to fix the sunroof - any ideas (I've checked the fuses etc.). I've not heard of any common problems with the electrics for the s/rs cheers wilf As for common problems i seem to sell quite a few sunroof motors! So much so that i dont have any left at present. I cant think how you would blow or rodd the drain pipe easily. Regards Colin Quote Link to comment Share on other sites More sharing options...
