k9unit Posted July 27, 2008 Share Posted July 27, 2008 where is the fuel cut off switch on 300tdi disco 1 cheers paul Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 27, 2008 Share Posted July 27, 2008 On the rear of the injector pump - there's a single wire going to it. There's a fuel pipe/banjo bolt in the way, so that needs to be undone if you want to remove the switch (20 or 21mm spanner). Banjo bolt is 15 or 17mm. Fuel will self syphon out of the pipework and filter when you disconnect it and will go all over the front axle. Raise the pipe as soon as it's disconnected to prevent fuel loss. Here - Les. Quote Link to comment Share on other sites More sharing options...
k9unit Posted July 27, 2008 Author Share Posted July 27, 2008 cheers mate Quote Link to comment Share on other sites More sharing options...
