Cliffh Posted August 21, 2008 Share Posted August 21, 2008 Hi, Looks like I am going to need to change the pas pump. I have found a thread about this but I don't know how to remove the auxillary belt (not looked too closely yet so apologies if it is obvious ) Not having any joy getting the Rave to work on my laptop so can someone give me some pointers on the removal / refitting of the belt. Also the D has done nearly 80k so is it work changing the belt at the same time? think I saw somewhere that it should be changed at 90k? Last quick question (sorry ) The front discs will need changing at the next pad change. Paddocks have the drilled / grooved discs at a good price at the moment, is it a good idea to go for these for normal road / load use or just go for normal discs? Thanks in advance Quote Link to comment Share on other sites More sharing options...
