Rolly Posted September 18, 2008 Share Posted September 18, 2008 Hi all, can someone tell me what I loosen off to fit a new serpentine belt. Every other car I've had adjusted off the alternator but I can't see it on the Disco (96 Tdi) Is it the belt tensioner? and if so which bolt do I undo? I'm not a fan of trial & error 'cos that usually ends up with me giving money that I'd rather spend on beer to a mechanic Cheers! Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 18, 2008 Share Posted September 18, 2008 Use a (15mm i think) spanner on the bolt in the middle of the tensioner pulley to swing the tensioner up off the belt and then the belt will slide off. The spring is quite stiff and it can be tricky holding everything in the correct positions to get the new belt on. Pete Quote Link to comment Share on other sites More sharing options...
Rolly Posted September 18, 2008 Author Share Posted September 18, 2008 Thanks Pete, I'm off to give it a go right now. Quote Link to comment Share on other sites More sharing options...
Rolly Posted September 18, 2008 Author Share Posted September 18, 2008 Yep, all fixed, the bolt on the pulley is a left-handed thread and you just lever the tensioner up & out of the way and after some swearing the belt just slips in. No bubbles in the reservoir and no pressure build up so I got away with that one. Think I'll put a spare in the car. Quote Link to comment Share on other sites More sharing options...
