mijim99 Posted November 14, 2008 Share Posted November 14, 2008 as a newbie i love this site ! finally biting bullet tommorrow im going for an engine swap (losing coolant, oil and she's tired ) so as my gearbox is clunking whilst slowing down its a complete swap, as this is my first landy (i love her! lol) should i expect any pit falls ? i have heard ill need to swap pump as i dont have ecu for replacement engine ??? anything else i should watch for ? many thanks mijim99 Quote Link to comment Share on other sites More sharing options...
Tear it up Posted November 15, 2008 Share Posted November 15, 2008 What type of engine is in it and what type of engine are you putting in it? If it's the same engine coming out as what is going in there shouldn't be too much of a problem. Quote Link to comment Share on other sites More sharing options...
mijim99 Posted November 15, 2008 Author Share Posted November 15, 2008 its a 300tdi out (98) and same in out of a (96) was worried about pump thinking it would be immobilised but doesnt seem to be ? well five hours in and engine and box sitting on floor yipee but at a cost !!!! lower gaiter rubber torn, wrist to finger tip slashed think ive broke my wrist !!!!!!!!! found chassis is rotten behind gearbox bracket will need to weld that up too my original engine has soaked the chassis in oil, clutch was on its last legs apart from that all is well lol! my flexi is goosed on exhaust oh and !!!!!!!!!!! the clunk i had i have sourced to the rear prop not been properly bolted in and a high spot on handbrake drum!!!! and the built in alarm is a pain when you disconect the battery ended up removing it and sticking it in rags inside the car lol tommorow the fitting wish me luck !!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
