mickeyw Posted December 24, 2008 Share Posted December 24, 2008 Hi All, I recently rebuilt my Marreli alternator on my 3.9 EFI with new bearings. I thought I had made careful note of where everything went, except for this bit.... I know it's a suppressor, and I know it bolts to one of the three bolts that go through the casing. But where should the other end of it (ring terminal) be connected to? And could its absence be what is causing erratic idle speeds? They were fine before I took the alternator off. Any ideas please?? Quote Link to comment Share on other sites More sharing options...
steve_d Posted December 24, 2008 Share Posted December 24, 2008 Put the black plastic cover on then it connects to the rev counter terminal and mounts to the stud directly across from the terminal. Steve ETA Your idle issue may just be a sticky extra air valve on the back of the plenum. They are famous for gumming up. Steve Quote Link to comment Share on other sites More sharing options...
mickeyw Posted December 26, 2008 Author Share Posted December 26, 2008 Nice one Steve, thanks, Suppressor connected now. As for the extra air valve (need to identify this yet), is it something that can be 'un-gummed' or is it a replacement job? Cheers, Quote Link to comment Share on other sites More sharing options...
steve_d Posted December 26, 2008 Share Posted December 26, 2008 It is bolted to the back of the Plenum chamber on the top of the engine (three allen head screws) and has a hose going to it from the throttle body. It can be stripped and cleaned. Try the Tech archive there is probably a piece in there about how to strip it because it is something that needs doing often. Not done one myself but I believe you remove the cylindrical part of the valve which then shows the plunger. I believe you then have to switch the ignition a few times to drive the plunger out (stepper motor). Ones apart you just need to clean it all up and reassemble. Steve Quote Link to comment Share on other sites More sharing options...
