Bobs Posted January 10, 2009 Share Posted January 10, 2009 My L series cluch will not disengage. The pedal feels right, perhapse slightly heavy, and there appears to be full travel on the slave cylinder piston and operating arm, but the clutch does not disengage. This fault occured mid journey with no other symptoms. Is this a common symptom for a failed clutch - I have only experienced clutch slip when I have had clutch problems with othet vehicles? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 12, 2009 Share Posted January 12, 2009 Could be a case of broken diaphragm on the clutch pressure plate. Quote Link to comment Share on other sites More sharing options...
