discovery_dan Posted February 3, 2009 Share Posted February 3, 2009 Hello, I am hoping that someone can help me, I have a leaking transfer gearbox rear output shaft oil seal. I have bought a new seal and flange to repair it but I wanted to know if it is likely that excessive end float is causing the leak? If the leak is ususally due to excessive end float, and not just a seal failure, does anyone know how to adjust the end float on an LT230 Disco transfer box?? I have checked the breather and it is clear. Thank you very much for the advice! Dan Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 4, 2009 Share Posted February 4, 2009 Preload is set on the inner bearing only by turning a threaded adjuster as shown in this picture- The outer (nose) bearing is just fitted in the housing. Thread on replacing the outer bearing and seal is here- http://forums.lr4x4.com/index.php?showtopic=6917 Les. Quote Link to comment Share on other sites More sharing options...
discovery_dan Posted February 6, 2009 Author Share Posted February 6, 2009 Thank you very much!! Quote Link to comment Share on other sites More sharing options...
