Mark Posted February 12, 2009 Share Posted February 12, 2009 Quick question for the collective; Is a 200TDI discovery fuel pump - the one in the fuel tank - a high or low pressure pump? Cheers Mark Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 12, 2009 Share Posted February 12, 2009 ? There's no fuel pump in the tank in either 200Tdi or 300 Tdi Discovery. There's only the fuel lift pump on the engine that sucks the fuel from the tank and then the injection pump. Quote Link to comment Share on other sites More sharing options...
white90 Posted February 12, 2009 Share Posted February 12, 2009 Plus all of the Fuel system is Low pressure before the FIP where the pipes are then metal to the injectors. Quote Link to comment Share on other sites More sharing options...
Mark Posted February 12, 2009 Author Share Posted February 12, 2009 Hmmm, OK, I am getting the sender unit confused with an in tank pump then.... that makes more sense though... Cheers Mark Quote Link to comment Share on other sites More sharing options...
white90 Posted February 12, 2009 Share Posted February 12, 2009 Yup Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 12, 2009 Share Posted February 12, 2009 Yeap, I've seen the fuel sender mistakenly advertised as being a fuel pump on some webshops. Probably that's what puzzled you. Quote Link to comment Share on other sites More sharing options...
Mark Posted February 12, 2009 Author Share Posted February 12, 2009 too much thinking about freelanders and not enough thinking about discoverys... Quote Link to comment Share on other sites More sharing options...
