Cutting out !!
Went to the tip this morning. On the way there the 90 cut out a couple of times, but re-started ok.
Its got a RRC 3.5 Efi, 4 sp auto. When revved up, as it settles back to idle, it drops below tickover
to almost stall, then picks up to normal tickover. I think this is why it cut out, because I was
coming up to a mini island, off throttle, when the revs dropped and it cut out.
Fortunately I was able to pull off the road to a rolling stop (heavy steering without the power)
Any pointers as to why or what might cause this ?
Thanks in advance, Jon
Does this sound more like an ignition problem, rather than a fuelling problem ?
If it is ignition, would converting to Megajolt be the answer ?
I've seen a Megajolt set-up on USA ebay for about £80 delivered, is it worth it ?
Has anyone got parts for sale in the UK ? I suppose EDIS 8, 2 coil packs+wires,
trigger wheel, sensor for trigger wheel ?? Anything else and at what cost ?
Cheers, Jon
