Desert Cat Posted June 4, 2009 Share Posted June 4, 2009 Hi guys, After changing engine belt, I had noticed the Viscous fan pulley is loose . Some guys told me I must change the timing chain cover but doing some reading, there is a possibility replacing only the bearing . Is there any special tool I need to extract the bearing out of the timing chain cover? does anyone did this procedure in the past? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 4, 2009 Share Posted June 4, 2009 Check out Silvio's thread here, http://forums.lr4x4.com/index.php?showtopic=32958 , and Silvio & his co-nationals' follow up HERE for pics and other details (use google to translate it, although pictures are enough). Quote Link to comment Share on other sites More sharing options...
Desert Cat Posted June 4, 2009 Author Share Posted June 4, 2009 Thanks a lot. This is the information I was missing. Our local authorized LR garage charges 300 US Dollars to do the job...!!! Quote Link to comment Share on other sites More sharing options...
