TURMOIL Posted July 2, 2009 Share Posted July 2, 2009 early Y reg Freelander. Any bright ideas on how to get the bottom pulley off, the stud into the crank just won't budge! I can't use heat for obvious reasons, and so far have tried withou anty luck with a half inch airgun, the torque settings are 100mn + 60 degrees + 60 degrees with thred lock when it's put on, thats mega tight!!! should I use a bigger air gun and risk snapping it off? anyone else ever taken one out sucessfully, I'd be interested to know how you did it Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 3, 2009 Share Posted July 3, 2009 You can use the starter motor to undo the crank bolt in the same way as you can with Defender and Disco's. Otherwise - lock the flywheel as shown in this thread - http://forums.lr4x4.com/index.php?showtopic=9652 Les. Quote Link to comment Share on other sites More sharing options...
TURMOIL Posted July 3, 2009 Author Share Posted July 3, 2009 You can use the starter motor to undo the crank bolt in the same way as you can with Defender and Disco's.Otherwise - lock the flywheel as shown in this thread - http://forums.lr4x4.com/index.php?showtopic=9652 Les. Thanks for the responce, I locked the fly wheel and stepped up a gear and used an inch airgun on it, bingo out she came..... cheers for the advice, I never thought it would be that hard to shift Bob Turner TURMOIL Quote Link to comment Share on other sites More sharing options...
