wozzer uk Posted December 30, 2009 Share Posted December 30, 2009 hi to every one and merry crimbo.. ok so here goes 200tdi discovery coming back from town the other day changing from 2nd to 3rd and nothing no drive checked other gears and nothing wont select anything so changes the transfer box to lock diff and low box and nothing still so gets it towed home by friend and checked linkages on top of transfer box they all seemed ok it was odd as there was no bang or grating everything was fine does any body know what the problem is or is it another gearbox to be fitted. it does seem as though something is going round in box just wont select anything. cheers warren Quote Link to comment Share on other sites More sharing options...
vougese39 Posted December 30, 2009 Share Posted December 30, 2009 remove the gearlever and check the yoke is not loose,take the t box output cover off and look at the splines, if all is ok then suspect the clutch has failed at a guess Quote Link to comment Share on other sites More sharing options...
