gaz0203 Posted December 30, 2009 Share Posted December 30, 2009 is there such a thing as a cold climate thermostat available for the 200??? my mates got a 88oc one in his, all checks about the heaters have been carried out as per the previous postings on here, it has a new matrix fitted, all cables are adjusted etc etc but the heater is proper rubbish, worse than usual. the heater hoses dont seem to get as hot as the top hose does so was just wandering whether there is a slightly hotter running stat availble anywhere to divert some more water through th matrix!! cheers Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 30, 2009 Share Posted December 30, 2009 88C is the only one. Is the thermostat leaking? The heater coolant supply comes from the back of the head, Are the heater flaps adjusted properly? Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted December 30, 2009 Author Share Posted December 30, 2009 yea all flaps are adjusted properly, guess it could just be a weak one full stop, stat is new so should be ok Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 31, 2009 Share Posted December 31, 2009 yea all flaps are adjusted properly, guess it could just be a weak one full stop, stat is new so should be ok Check it. IME, a large proportion of new ones leak. If there is any heat in the upper hose before it reached normal temperature, it is leaking. Quote Link to comment Share on other sites More sharing options...
