chadler Posted January 7, 2010 Share Posted January 7, 2010 I'm in the process of winterising a Defender, and as such an Eberspacher D2 Air Heater has been installed into the vehicle, the exhaust exiting in a through-panel skin fitting. The next addition is an under bonnet webasto coolant heat exchanger which uses the the same diameter stainless flexible 24mm exhaust hose. Rather than install a second exhaust exit skin fitting under the first the neatest solution would be if the two exhausts are plumbed together with a Y connector with a single short length of flexible pipe then leading to the current exhaust fitting. Is there anyone out there capable and willing to knock up a stainless steel tubular Y connector, with the input and output hoses sized to accept 24mm stainless flexible pipe, held on by clamps? I invisage that this would be a very simple fab, but I don't have the facilities or skill set to do this myself. I am in SE england but the finished product will be very light and jiffy bag sized so I don't think geography is a limiting factor. Anyone interested in helping out? Quote Link to comment Share on other sites More sharing options...
scottydog Posted January 7, 2010 Share Posted January 7, 2010 pm sent mate Quote Link to comment Share on other sites More sharing options...
