joe sharpe Posted January 16, 2010 Share Posted January 16, 2010 hi,i have a 1991 200tdi discovery and i am wanting to make some brake pipes but am unsure if the fittings are metric or imperial and is the pipe 3/6" o/d . also has anyone used a pnumatic bleeder kit any good ? with thanks joe Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 16, 2010 Share Posted January 16, 2010 Having just done similar research for my '92 200tdi 90, 3/16 (not 3/6) is the standard pipe size for brakes. M10 fine seems to be the standard thread for most joints, though I believe there is the possibility of the odd imperial still featuring. The Pneumatic bleeders work ok, as long as you don't set the pressure too high, if you do brake fluid just ends up everywhere. Quote Link to comment Share on other sites More sharing options...
