ABS pump damaged?
Good day. I have a TD5 with ABS and TC. Just a couple of months ago I received the Nanocom and proceeded to erase all faults and tried to bleed the ABS pump. However, the bleed wasn't completed correctly (I didn't press the pedal while Nanocom sent the signal). Since there, pump presents a failure called 17-04 pump failure 2. How can I be sure that pump is really broken? I already have cleaned and tightened ground screw and pressed pump loom with no result. Pump is not making noise, but when I try abs bleed in Nanocom with pressed pedal, it goes a little down every time ABS relay sounds. Also, 3 amigos appeared.... please your help, I really need ABS due to my tyres (I have General SAG 7.50, and you know that's not the best ally for road and city....
