100 david Posted February 15, 2010 Share Posted February 15, 2010 Hello all, ok a friend of my wife has a 2001 2.0 diesel Freelander, when she stops the engine you can hear what i would discribe as a electric motor or fan noise comming from the left front area of the vehicle then after a minute it stops, now i know the P38 Range Rover inside out as i own one but the Freelander is new to me , so is it a fan or a motor i can hear running, its not the 2 for the radiator. I would be very grateful if one of you Freelander guys could help Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted February 15, 2010 Share Posted February 15, 2010 Some higher end models have a fuel burning heater in this position which cuts in on cold days. Sounds just like a fan and last for a few minutes after you switch off. The tell tale is the mini exhaust pipe under the front wing just in front of the tyre. Quote Link to comment Share on other sites More sharing options...
100 david Posted February 15, 2010 Author Share Posted February 15, 2010 Some higher end models have a fuel burning heater in this position which cuts in on cold days. Sounds just like a fan and last for a few minutes after you switch off. The tell tale is the mini exhaust pipe under the front wing just in front of the tyre. Thankyou, i used to be a truck driver and i thought to myself it sound just like a overnight heater from a truck, i looked under the front wing and there was the tell tale pipe and i thought no , cant be. Thankyou very much for that, you learn something new every day Quote Link to comment Share on other sites More sharing options...
