ally Posted March 2, 2010 Share Posted March 2, 2010 hey guys rear wiper on my 00 td5 has stopped working ,the skoosher is working, any ideas cheers ally Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 2, 2010 Share Posted March 2, 2010 Been there, done that a few weeks ago Water gets in the wiper mechanism and it siezes-up. A new one is about £90, but they can be repaired as they rareley burn out. If the fuse is ok, and power is getting to it, then the spindle has siezed. Remove the arm, then the nut underneath it (you have to remove the spare wheel). Take the door card off, and you'll see the wiper mechanism. Disconnect the plug, then remove it (10mm socket I think). The cover is a steel plate - held on with 4 (?) screws. Remove them and the cover plate and you'll see the gearing. The problem is the shaft that the wiper arm is attached to - remove the small clip that holds the main gear in place and then press or tap the shaft out. Clean it up, grease, replace. Pack the internals with fresh grease to about 2/3, and put it back together. Les. Quote Link to comment Share on other sites More sharing options...
ally Posted March 2, 2010 Author Share Posted March 2, 2010 thank you les ill try that. do you know if it is fuse 18 on fuse board that controls it ? ally Quote Link to comment Share on other sites More sharing options...
