bandit177 Posted May 5, 2010 Share Posted May 5, 2010 Please help me! I have just fitted a Series 3 bulkhead to me Series 2a. All the front wiring came with the bulkhead and I have managed to get all the front electrics working. For the rear I purchased a new rear loom which plugs in at the bulkhead. I have got the rear indicators and brake lights working but no rear lights. I have checked the bulkhead connector and have no power going to the rear lights but obviously do to the indicators. All fuses are ok. Any ideas what I need to check next would be gratefully received! Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 5, 2010 Share Posted May 5, 2010 Please help me! I have just fitted a Series 3 bulkhead to me Series 2a. All the front wiring came with the bulkhead and I have managed to get all the front electrics working. For the rear I purchased a new rear loom which plugs in at the bulkhead. I have got the rear indicators and brake lights working but no rear lights. I have checked the bulkhead connector and have no power going to the rear lights but obviously do to the indicators. All fuses are ok. Any ideas what I need to check next would be gratefully received! Is the rear loom for the series 3 or the 2A? Have you got any wires (particulary red ones) left over? Are you using the the 2A switches or the ones from a 3? Have you got a wiring diagram? This is the series 3 one: Land_Rover_Series_III_wiring.pdf 9 and 10 are the tail lights, 24 is the S3 lighting switch. From Landroverweb book 6, page 48. Quote Link to comment Share on other sites More sharing options...
bandit177 Posted May 5, 2010 Author Share Posted May 5, 2010 Is the rear loom for the series 3 or the 2A? Have you got any wires (particulary red ones) left over? Are you using the the 2A switches or the ones from a 3? Have you got a wiring diagram? This is the series 3 one: Land_Rover_Series_III_wiring.pdf 9 and 10 are the tail lights, 24 is the S3 lighting switch. From Landroverweb book 6, page 48. Quote Link to comment Share on other sites More sharing options...
bandit177 Posted May 5, 2010 Author Share Posted May 5, 2010 Thanks for your quick response. All the wiring is Series 3 as is the dash with series 3 switches. I dont have any spare wires and all colours seem to be matching ie B R and RB. What I can't understand is the front is working fine and the rear seems to branch off from this. I think I will peal back the outer insulation and see how it joins. Could there be any issues to look at in the dash please? Thanks again. Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 6, 2010 Share Posted May 6, 2010 What I can't understand is the front is working fine and the rear seems to branch off from this. I think I will peal back the outer insulation and see how it joins. Could there be any issues to look at in the dash please? My two guess are - the rear loom is defective, or the lighting switch is defective. If you've got a multimeter, have you tried testing for voltage starting at the switch? The diagram shows the front and rear coming off different terminals. You could also do a continuity check from one end of the rear loom to the other to eliminate it as an issue. Quote Link to comment Share on other sites More sharing options...
