Lucky13 Posted May 11, 2010 Share Posted May 11, 2010 Hi Guys Looking for some experienced advice. I am building a 200tdi 90 for comp safari, it will be pretty standard as I want to keep it ALRC standard class. The only major changes are td5 fuel tank in the rear, battery in rear, wash tank in rear to try and load the back end up as the back body has been stripped out and just has side/back panels. I will also be running a full lightened hardtop. But I cant decide on what shocks and what mounting positions to use. I have to use the standard mounting points for ALRC events but can also use additional shocks. Basically what I am asking is what are you running for comp safari's: FOX,OME,KING,Terrafirma? And what shock positions are you running?? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
