Breathers
Sorry about this folks if this question has been asked a 1000 times before.
I have a defender 130, 300TDI, my plans are to fit a safari snortel, can anybody tell me if i need to fit axel breather's or not ?
It does not say anything about breather's on the instruction's manual from Safari.
Many Thanks
Many Thanks
Your LR should already have them, plus one each for the main box and transfer box. Three should come up next to the bulkhead in the engine compartment and one under the back body somewhere.
You can add timing chest and bellhousing breathers (not standard), bring them all together in a manifold and then run one pipe up the snorkel - there are kits but you can also do it with bits off ebay.
Unless you plan to spend all day and everyday up to the wheelarch eyebrows in water then the standard LR arrangment is just fine (with the wading plugs in of course).
