Desert Cat Posted August 9, 2010 Share Posted August 9, 2010 Hello all, I would like to fit an Oil pressure gauge on the TD5 engine using a VDO Sender Which one to fit the TD5? 5 BAR (EARTH RETURN) M10x1 - M4 NUT or 5 BAR (EARTH RETURN) 1/8-27 NPTF - M4 NUT Where to locate the sender? Replace the stock one or connect in parallel? JPG enclosed Should a TEE-PIECES be used here? OIL T-PIECE 1/4 UNF (M&F) TO 1/8 NPT (F) ??? Quote Link to comment Share on other sites More sharing options...
mayur Posted August 9, 2010 Share Posted August 9, 2010 hi mate you will have to add a t-piece and have you oil pressure switch working and the BCU mointers oil pressure, something like this will work but it over kill http://cgi.ebay.co.uk/T-PIECE-OIL-PRESSURE-TEMP-SENSOR-SENDER-Adaptor-/370408762990?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563e152e6e#ht_4316wt_902 Quote Link to comment Share on other sites More sharing options...
