lawrence Posted September 29, 2010 Share Posted September 29, 2010 So of ebay I have just got a wading kit, which contained the following 1 - front axle .. 2 - rear axle .. 3 - gearbox ... 4 - transfer box ... 5 - timing belt cover ... 6 - fuel tank breather !!!! Along with all the pipe. They also was 2 wading plugs. So my question, Is this all the breather holes and the wading plugs are spare or should they go somewhere aswell and if so where. Also do I need the fuel tank breather. It would be of grat help if anyone had pictues of all the breathers fitted so I know where they are all to go. thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
matt bristol Posted September 29, 2010 Share Posted September 29, 2010 the exteinded pipes are to allow you to vent the axles into the snorkel to prevent suction drawing in water when the axles cool in water. The plugs are for the bolt hole in the bottom of the bell housing and on the timing cover to prevent water ingress No idea about the tank breather Quote Link to comment Share on other sites More sharing options...
