chris_oakley Posted October 11, 2010 Share Posted October 11, 2010 Compression Test Carried out on my 200 Tdi. Results are as follows. cyl1 400psi cyl2 380psi cyl3 290psi cyl4 390psi What sort of results should i have expected ? Quote Link to comment Share on other sites More sharing options...
gee1599 Posted October 11, 2010 Share Posted October 11, 2010 cylinder number 3 is to low thats why you have smoke and a missfire have you checked the rockers / push rods on cyl 3 ? Quote Link to comment Share on other sites More sharing options...
chris_oakley Posted October 11, 2010 Author Share Posted October 11, 2010 Push rods are straight, rockers were in take but i will check gain 2morow/ Havnt checked tappet yet, will check adjustments tomorrow. Quote Link to comment Share on other sites More sharing options...
gee1599 Posted October 11, 2010 Share Posted October 11, 2010 if they are to tight it will have low compression also did you do a dry and wet compression test ?? if you did what was the wet reading on cyl 3 ? Quote Link to comment Share on other sites More sharing options...
chris_oakley Posted October 11, 2010 Author Share Posted October 11, 2010 just done a normal dry . as read that doing a wet one isn't advisable on the tdi. i could do a wet one 2morow, if thats the way forward ? so if i just loosen the tappet on number 3 il be able to see if its made a difference. Quote Link to comment Share on other sites More sharing options...
gee1599 Posted October 11, 2010 Share Posted October 11, 2010 you can do it but dont put to much oil in and turn it over first with out tester or glowplug in Quote Link to comment Share on other sites More sharing options...
chris_oakley Posted October 11, 2010 Author Share Posted October 11, 2010 Put the oil in spin it over by hand once , then attempt to do a wet test. Quote Link to comment Share on other sites More sharing options...
gee1599 Posted October 11, 2010 Share Posted October 11, 2010 yes then take the readings Quote Link to comment Share on other sites More sharing options...
chris_oakley Posted October 11, 2010 Author Share Posted October 11, 2010 I will do this then. Wish Me Luck Quote Link to comment Share on other sites More sharing options...
chris_oakley Posted October 12, 2010 Author Share Posted October 12, 2010 Iv Decided going to pull head of . spoke to land rover specialist and they think the head gasket might be blowing acrossed the bores . at least with the head i should be able to see some sort of damage if there is some. Quote Link to comment Share on other sites More sharing options...
gee1599 Posted October 12, 2010 Share Posted October 12, 2010 if it was a cross the bores it would have 2 cylinders low on compression Quote Link to comment Share on other sites More sharing options...
