dsuk Posted November 14, 2010 Share Posted November 14, 2010 Hi, I've got a 1994 300TDI that has developed a strange noise this morning. Whilst driving along I suddenly realised than when the engine is under load (e.g. going up hill and accelerating) there is a sucking noise. It sounds to be coming from the passenger side behind the glove box and the wierd thing is that when I reach my target speed and throttle back, the niose disappears completely. The sucking noise is quite loud and I can't see any hoses that are detacted or broken. The noise does not occur when the vehicle is stationary and I rev the engine. power seems to be a bit down compared to yesterday as well. Any suggestions of where to look? Thanks, Dave Quote Link to comment Share on other sites More sharing options...
russ1 Posted November 14, 2010 Share Posted November 14, 2010 Sounds like you might have a pin hole in a intake or boost hose, give them a good going over and see what you can find. Russ Quote Link to comment Share on other sites More sharing options...
euneka Posted December 27, 2010 Share Posted December 27, 2010 Hi, I've got a 1994 300TDI that has developed a strange noise this morning. Whilst driving along I suddenly realised than when the engine is under load (e.g. going up hill and accelerating) there is a sucking noise. It sounds to be coming from the passenger side behind the glove box and the wierd thing is that when I reach my target speed and throttle back, the niose disappears completely. The sucking noise is quite loud and I can't see any hoses that are detacted or broken. The noise does not occur when the vehicle is stationary and I rev the engine. power seems to be a bit down compared to yesterday as well. Any suggestions of where to look? Thanks, Dave Hello Just read your post after having exactly the same thing happen on my 200tdi discovery. Did you get to the bottom of it? Thanks, Mike Quote Link to comment Share on other sites More sharing options...
davek0974 Posted December 27, 2010 Share Posted December 27, 2010 Hello Just read your post after having exactly the same thing happen on my 200tdi discovery. Did you get to the bottom of it? Thanks, Mike It sounds like an inlet pipe has delaminated and is being sucked shut, check all the rubber air hoses Quote Link to comment Share on other sites More sharing options...
euneka Posted December 27, 2010 Share Posted December 27, 2010 Thanks Will check that out. Mike Quote Link to comment Share on other sites More sharing options...
thewhizzard Posted December 29, 2010 Share Posted December 29, 2010 Hi same thing happened to me, turned out it was just a jubilee clip that had snapped of one of the turbo hoses, new clip and bobs your uncle! Den Quote Link to comment Share on other sites More sharing options...
euneka Posted January 2, 2011 Share Posted January 2, 2011 Hi same thing happened to me, turned out it was just a jubilee clip that had snapped of one of the turbo hoses, new clip and bobs your uncle! Den Thanks for that. Will check the hose clips. Mike Quote Link to comment Share on other sites More sharing options...
