sirus Posted November 18, 2010 Share Posted November 18, 2010 i have got a problem with my 300tdi auto, ive took the air flow mtr off changed the fuel pump and the first injecter, an now it wont change gear like it did before anyone any idears chears Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 18, 2010 Share Posted November 18, 2010 IIRC it will be a fully mechanical box like mine, so unless you have caused an engine problem with the bits you have changed I'd suspect that somehow you altered the kickdown cable adjustment when you were working on the fuel pump? Just a guess. Quote Link to comment Share on other sites More sharing options...
sirus Posted November 19, 2010 Author Share Posted November 19, 2010 IIRC it will be a fully mechanical box like mine, so unless you have caused an engine problem with the bits you have changed I'd suspect that somehow you altered the kickdown cable adjustment when you were working on the fuel pump? Just a guess. Quote Link to comment Share on other sites More sharing options...
sirus Posted November 20, 2010 Author Share Posted November 20, 2010 i if the fuel pump isnt workin right, will that cause the same problem ? im going 2 try your idear this weekend thanks Quote Link to comment Share on other sites More sharing options...
